ibfunru
ibfunru
I have a 66 valiant with the original 273 2brl, runs fine sounds fine smokes badly, 26000 miles showing one past repaint stock ....guys should I keep it true to what it has always been or pull the 273 and keep for some future buyer in a box while I use a new 318, 340, 360 for as long as I own it, I am sure if I did that you all may suggest to get rid of the stock 13 inch tires and hub caps?.....Also I see 2507 made but cannot find out how many were only v8 like mine.....If I do change to a larger motor at what point do I have to then change the trans to a stronger unit and same goes to rear end mods.....This car is as old as me, and being I am a disabled vet it is in better shape than me too (haha) ......does this car deserve to just stay what it has always been - just rebuild the motor and keep it true.....I value your opinions both ways
I owned a 1970 4 door as a 19 year old for 4 years, then a time capsule 67 2 door 3 speed on Column both 6 cyl while in service in South Carolina for 4 years too.....just found this 66
