A friend of mine has a 273 4 barrel motor for sale. He bought a 67 Barracuda, the body was totaled out but had a low mileage 273 in it. He went through the motor & put in new bearings, rings, oil pump, cam bearings, freeze plugs, & timing gears & chain, it is a standard bore block with standard main & rod bearings. He has the factory cast iron 4 barrel intake, but it has an after market aluminum intake on it now The motor is located in Onalaska, TX, we will not ship this, it is pickup only. He is asking 2,500.00 for it, we can help load it in whatever vehicle you bring.
