moparmat2000
hi Y'all
i have a set of smoothed steering column uppers. perfect for your floor shift steering column conversion. these are from an automatic column shift car, and have been ground down, filled in, smoothed and primered. these are NOT original floor shift pieces, but those are now made of unobtanium now. these are the next best thing. they were sandblasted to strip them, and the filler was a structural aluminum paste. this stuff wont crack out. they are being sold in primer, and require a final wet sand prior to your color of choice. i have an awful lot of work in these to make them what they are. i am sure if you are looking for these parts you know they are pretty hard to find. pictures show the sides that were smoothed and filled so you know what you are getting.
these are from a 67 A body, and have the factory for 67 drilled hole in the lower collar for the set screw, may fit the 68, 69 columns which use a different set screw arrangement but im not too sure on that. i would like to get $75 plus the ride. located in Abilene texas 79606
thanks
matt
thanks
matt
