67-69 Barracuda Fender Patch Help
cudakid67
Riverside, IA
Looking for some comments about the fender patch panels that are available?
Quality?
Fit?
How many different people are producing them, I see they are available at many vendors.
I can usually find them in the $60 - $80 range but I have found them for as low as $32, see the link below.
Thanks in advance for all of your input.
http://c2cfabrication.com/store/product_info.php?products_id=7906
prob good to use if theres nothing left but if your just cuting out a flat or slightly curved piece you can use any door sheet metal for replacement.
My experience is that some are made out of Nice heavy/thick metal and some are Thinner than I would make for myself.
x2^ i needed some sheet metal to repair a couple of spots luckly my dad had a door off of a new dodge dakota he got from the body shop he works at and surprisingly enough the sheet metal was just as thick as the demons.
:blob:
worked well. but anyways yeah basically you want to replace with the same thickness sheetmetal. as they differ from manufacturer to manufacturer.
