67-9 valiant 2dr sedan parts wanted
Sedanman
67-9 Valiant specialist
chicago Il
I am working on a 67 Valiant Signet 2dr sedan v8 car. I will be dropping a 340 in it over the summer & need some parts. I do have some parts to trade.
I am looking for a good drivers door window reg for 2dr sedan
73-77 v8 ps set up from same car,the box & pump with engine bolts (prefer somewhat local due to weight) I am using them as a core & just want a matched set up.
small block stock hydrolic rocker assy's prefer min wear or new condition,complete with shafts & rockers only
68-73 valiant only rear window gasket
Any other 67 signet parts will be considered
I will be selling off the original complete 273 2bbl engine with rebuilt heads,904 trans,3 core rad,mint 312 shroud & 108" wb single exhaust. The engine runs great,has a new carb ,trans shifts smoothe & is my daily driver. The engine is from air cleaner to pan & tail shaft to water pump pulley. I am keeping the kickdown linkage,spool engine mounts,engine fan,trans lines,trans inspection cover,alt & maybe the right angle oil filter adapter
I have the window regulator if you can't find something closer.
Thanks, Mark
I Found the ps set up & maybe the rear gasket. Does anyone have the rest?
Ya know,I had a pile of them & looks like I sold every 1 I had even the one I was keeping for myself :(. Thanks for the link. I've been supplying 67-9 Valiant parts all over the globe for 20 years & now I need parts lol
That great to know I might send you a wish list for my car. I have a few left over stock parts from my car I no longer need if you want a list & pics.
Cheers
