I did it to mine. get everything from the donor car. pretty easy.I'm getting ready to find out. I'm putting factory a/c in a 68 dart with 273 engine. I think hardest part will be cutting the firewall correctly for the fan, drain and evap. lines, other than that it looks like everything bolts on. You will need to add a vacuum tap from the engine to run the controls. Good luck.
Hi I have a 67 barracuda non ac car is it a lot of work to make it a factory ac car .
