[Found!] 67 Barracuda fastback window channel moulding
512Stroker
We are all here because we are not all there.
Freedom, MO
I am looking for a source for the window channel felt that goes inside the channel located between the driver side/passenger side crank up window and the wing window.
Thanks
Are you looking for the mylar insert for the vent window door frame for the front glass or the quarter glass seal that goes between the front door glass and the quarter glass or both? I have the mylar inserts available in a reproduction for $95 and NOS inserts for $200 for the pair. The quarter glass seals are $22.
