DallasMan2000
Here are a couple picks of the radiator/fan.
That does not sound like an ammeter. Right after start up with an ammeter the needle should head toward C as the system recharges the battery. Either the gauge has been converted to a voltmeter, or the alternator is not charging to recuperate the system after the drain to spin the motor.So the needle went slightly towards the D when the car started then quickly moved back to the middle. I also measured 12.17 volts at the alternator post once the car started.
Its an ammeter. A Voltmeter would be 0 with the the engine off.That does not sound like an ammeter. Right after start up with an ammeter the needle should head toward C as the system recharges the battery. Either the gauge has been converted to a voltmeter, or the alternator is not charging to recuperate the system after the drain to spin the motor.
Looks to me like a bubble top radiator (correct) and the matching water pump for pre-70 cars.
Unless it's wired to a source that is always hot. You could disconnect the battery and see if the needle stays in the middle or drops toward D, right?Its an ammeter. A Voltmeter would be 0 with the the engine off.
You mean there are people out there ignorant enough to wire in a winch, snow plow or other high amp draw THROUGH the factory amp gauge wiring? Even "I" would wire something like that in COMPLETELY SEPARATE from the rest of the system.Most of them did not have large alternators, either, and some of the big ones had the factory bypass, known as the Police/ Fleet / Taxi wiring.
My 70 440-6 RR managed to "eat" the bulkhead terminals way way back about 1973 or so. Of course Al Gore had not invented the internet, yet, so I drilled out the wire holes in the connector and doubled up some larger gauge wire and fed through there. I also SOLDERED THE STUD CONNECTIONS in the ammeter, (to the shunt) which very interestingly, is documented by someone else in "today's" generation.
I've seen at least a dozen pickups with melted ammeters which had had such things as driving lights and or winches added. Another "biggie" was snow plow hoists, which were operated by large electric motors.
I agree. I gave it my best shot in the post above. Tommorrow is a long day so gotta sign off.Unless it's wired to a source that is always hot. You could disconnect the battery and see if the needle stays in the middle or drops toward D, right?
I think that I would disconnect the power wires related to the fan set up and then see how the ammeter reacts. I think that would tell you if it was the fan wiring that was causing the issues.
I can't understand that there is a hot wire from the battery terminal AND a hot wire from the starter relay all headed for the fan...
It is or was common to wire an electric winch or a plow to the battery. Many of them need the power (amps) that only the battery can provide. If wired to the alternator, battery power would have had been drawn through the ammeter and its wires anyway. Definately a better thought out system was needed for sustained high current equipment. At minimum heavier duty wiring, meter and connections, and a bigger battery.You mean there are people out there ignorant enough to wire in a winch, snow plow or other high amp draw THROUGH the factory amp gauge wiring? Even "I" would wire something like that in COMPLETELY SEPARATE from the rest of the system.
"Through the ammeter" is not how they are wired, but they put so much load on the charging system that they damage the charge wire, bulkhead connector, and ammeter--just like on A bodies and just like we are talking here (likely). I've said before, my old 70 RR ate the bulkhead connector and damaged the ammeter way back i the early 70's. And it didn't have a winch, lololYou mean there are people out there ignorant enough to wire in a winch, snow plow or other high amp draw THROUGH the factory amp gauge wiring? Even "I" would wire something like that in COMPLETELY SEPARATE from the rest of the system.
How does it get to the battery, AKA how large is it? Photos can be "skewed" but I see nothing there except for the one you mentioned, that looks very heavyThese is a lot going on at the starter relay - see pic below. The large black wire coming in to the top comes directly from the alternator post.
Also, check to make sure the voltage regulator is well grounded. Cleaning off a small spot of paint around the screw hole should do it. I like to put a dab of dielectric grease there to keep corrosion at bay.The voltage regulator plug looks like it came as part of the M&H harness.
Everyone is different. That's a pretty good response for someone who came in and asked "does this work?"Am I asking the right questions and does this seem reasonable?
