tekslk
Looking at changing the rear wheels to big bolt pattern what must I do. Slos seen on spike tv 600 holley carb double pump conversion that looked real insteresting anyone no anything about it?
8 3/4do you have a 7.25 or an 8.75 rear?
I had put 10 inch brakes on the rear when I put the 8 3/4 in las summer do I still need the diffrent plates and stuff or just the axles?you can get your axles and brake drums redrilled for the 4&1/2 inch pattern,but it's not ideal for high horsepower. you can also buy aftermarket axles,not sure but you might have to change to B-body backing plates and brake drums for those. if you have C-body axles shortened and resplined you need to change backing plates and drums.
