Knock the roll pin out of the coupler that slides onto steering box splines. Remove shift rod if applicable, Inside where the column meets the floor... remove the 3 bolts 1/2 that hold the collar, then move up to right under the dash, at the column, remove plastic trim plate and 3 more 7/16 nuts and ground wire. Pay attention to how far you move it in regards to wire harnesses n such. Lower and slide back, have someone coax the coupler along so it doesnt come apart and drop the steel halves and locater onto the dirt/ground.
