Specs of that badass 360???
Here are the basics of what Mike at MRL Performance did on this build:
It's a mild build with excellent manners. Just what I was looking for.
360 block prepped and blueprinted for build
Stock crank, reconditioned/balanced
Aluminum heads, new valves/springs, porting, HP valve job
Stock rods, w/ARP bolts
New flat top Hyper pistons/rings
New Bearings/freeze plugs
New Roller rockers
New Hydraulic cam 228* .480" lift
New Double roller timing set w/tensioner
New Stock type center sump oil pan
New Ported Melling oil pump
New Aluminum dual plane intake
New 750 vacuum secondary carb w/electric choke
New FBO ignition system
New 8mm wires
New Champion plugs
New damper
New water pump
New flex plate
New Chrome steel valve covers w/breather & PCV
Dyno run and tuned
