MechEngr
I been working on this 67 Barracuda for about the past year and a half with the mechanical portion of the build finally completed.
360 Magnum (.030 over to 365 CID)
Comp Cams: Duration 265/273, Lift.506/.506
Kieth Black Pistons (KB107.030, 10.5:1 CR)
PIE Heads (Stage 1 Ported)
Edelbrock Air Gap (Port Matched)
Mopar Perf. Timing Chain and Gear Set
Holly Sniper Hyperspark Distributor
Holly Sniper EFI and 340 lpm Fuel Pump
FlowCooler water pump
Kevco oil pan
TTI Shorty Headers
46RH Transmission
8 3/4 differential with 3.23 gears (shortened 2")
Borgeson PS
4 wheel power disc brakes
I still have a lot of work left to do. There are a lot of mysterious rattles and electric bugs to fix and the body work could use lots of help.
Takiing it a dollar at a time.
Kevco oil pan
TTI Shorty Headers
46RH Transmission
Borgeson PS
