sleepyhead416
GREAT WORK scoop got to go LOL Put the whole 1/4 panel on you can do it.
I am not a welder:banghead:
I have a question about the trunk extension. Should it be spot welded to the fender or attached with panel glue like 3M?
This is the first time that I've seen this thread and I noticed your scoop issue. I once worked with a guy who had that scoop on a 68 Barracuda with a steel hood. What he in fact used, was the complete hood and scoop from 73 Dart Sport. The hood on the Dart Sport is exactly the same as a 67-69 Barracuda so you can use an original steel one or a fiberglass one if you want.
try spot welding at least six inches apart and after spotting six welds switch to the other end of the panel. at each spot weld, take your dollie at inside of the panel and tap medium heavy taps with your very smooth body hammer to the weld. this will stretch the metal back to it's original position. Welding will make the two panels move closer together every time you weld a spot. Your body hammer MUST not have any scratches in the striking head or the marks WILL transfer to the sheet metal. Good lick, you can do it. Go slow. Your panel should take you one entire day to get about 75% welded up. Atleast thats how long it would take me using a MIG welder. I use a TIG now for sheet metal. Still the same process though only the heat is easier to manage but the learning process is longer. L.O.L!!!!!
Good advice. Still have to take your time and hammer & dollie tho. I use the air gun to help with heat control also. Weld spot, move down the panel every 4-6 inches, to the end of panel, blow air over panel to bring heat down, repeat. Takes a long time but much better results.
The body man that first recommended to me that I use the adhesive did his best to demonstrate how well the adhesive works. He had just finished hanging a pair of quarters on a car and had left over adhesive in the tubes. - So he takes a number of scrap steel panels and glues them together and let them cure out. Later he had me come back and try to break them apart. I hammered on them. I put them in vices. I twisted them with vice grips. I tore the metal but could not break the bond from the adhesive.
Then he had me try to do the same with some other scraps he'd welded together. Usually the metal would start to tear next to the welds when I tried to exert stresses similar to what I had on the glued pieces. He was firmly convinced that the adhesive was a stronger method of attaching panels. After he had me test those scraps of metal I became sold on the idea myself.
He is recently retired but had been a body man for over 40 years. He touted the advantage of not having to worry about panel distortion and said he'd never go back to welding panels on again. (He did still weld the areas where distortion wasn't an issue and anything that was structural in nature)
I have used the glue method but for a unseamed appearance I always but welt with a tig welder. Mig for small patch stuff for a quick fix. I might try the joint type weld if I someday get a tool to make the flanges. My worry would be that you may warp the panel just by putting the flange in it. I'm no expert by any means but my experience tells me that if it works and your happy with it, then who cares how you do it as long as it holds strong. Besides, were in this hobbie to enjoy it and learn new things as well as meet new like minded people.
