Cudapete
After finishing my 68 gts for the most part I started to tear down my fathers 67 dart and decided to start a resto thread,This car is a pretty much untouched and completely original other than a color change from red to green in 1975, so it needs everything! so far i've pretty much tore down the whole car with only the front suspension and brake lines left to pull out. from there I plan to repair the 2 bad floor pans under the rear seat and the couple small holes in the rear passenger frame rail, then rebuild the suspension to get it rolling again, so far thats as far as my plan has gotten. This car will be restored stone stock with the only modifications being frame connectors, electronic ign, and maybe a hydraulic cam. So far we've found 2 build sheets, we have the fender tag ,registrations back to 1970, and the certicard holder(unfortunatly no certicard) Hope you enjoy the pics.
