67 Dart Gt 383 Fender Tag Decoding Help
383-4speed 323 sure grip
Bright blue poly paint, dark blue bucket seat interior, dark blue upper door frame paint.
D70-14 redline tires (Qty 5)
Scheduled production date May 23, 1967
Bucket seats
fender turn signals
Sill moulding
Disc brakes
Am radio
Tinted glass all windows
Ordered car
Bottom line is:
LP23 is car type & body, eng, trans, tires, SPD, SO number
E is upper door frame paint
TRM
P6B is dark blue bucket seat interior
Thank You. I had found and used this, but there were a couple of numbers I was not quite sure about.
You are correct, very accurate and easy to use.
Thanks a Bunch
Jere
you know about the GTS registry?
http://www.gtsregistry.net/www.gtsregistry.com/index.html
Repost a photo of your fender tag. Many times a code that does not come up on the web sites can be decoded by matching another fender tag from members like me with one family cars (ie 100% known history)
Also you can get an IBM card for your car from Stellantis historical. I can help you decode it.
Chrysler Historical new contact info.
Lastly post some photos!
b-4 = 564 - Bucket Seats
h-7 = 517 - Hood Mounted Turn Lights
j-4 = 544 - Body Sill Narrow
u-1 = 691 - Sold Car
D-9 = 479 - Disc Brakes
X-1 - 521 - Tinted Windows - All
A-4 = 404 - 3.23:1
X-8 = 408 - Sure Grip
TRM-P6B = Premium/Bucket/Blue
PNT-881 = Bright Blue Metallic Mono Tone
UBS-E = Interior (door) Dark Blue Metallic
LP23 = Dart GT Hardtop
62 = 383
3 = 393 - 4-speed manual
285 = D-70x14 Redline Tires / Set of 5
523 = May 23, 1967
04042 =SO Number
Alan
Also, on the 3rd line, The P under the T?
I don't think T is a P maybe a 1 which would be full trim ring on the horn
Full horn ring
Standard horn ring
If it's T4 it's a console mounted vacuume gauge
This is a 66 version but will be similar to 67
If it's T7 it's the console tach
T9 undercoat / hood insulation.
Although the tag has "J" on the top row it is "j"
I agree lower case J but both 67 Dart GTs I have don't have glove box lights and have h7 and j4
Dodge charger fender tag calculator calls out h4 as fender top turn signals and j4 as narrow sill molding.
The fender top GT trim.
That one is my mistake, I looked at a 68 code,
67
