67 Dodge Dart front end rebuild questions
coffeedart67
Southeast South Dakota
Still debating wether I want to remove the k-member for blast and paint, if I do, I figure I just as well rebuild the front suspension. Is this something I can do myself? I have rebuilt the entire front end on a 73 Chevelle and a 86 Dodge Shelby Charger, and repalced ball joints on a 98 Dodge Dakota. Any special tools required? Also are there any one off parts on the 67s other than the idler arm, which I had replaced in 94, so it should be good. probably will spring for a service manual, what do I look for for a service manual? I have a haynes for Darts but that is kind of basic in some areas.
Thanks
Getting a tool set like this will help tremendously, although you can sort of make up your own or use alternatives, if you are creative.
I found this set here, but it may be cheaper elsewhere...
