fredsmedina
6 Dart 7 MOPAR OR NOCAR
I Ordered my rubber super front end rebuild kit from P-S-T. a week or two ago. I thought I needed the Kit for the 1967 Dodge Dart, but it turns out that since my car isn't an original V-8 car, the K frame that was put in is from a later year.
Can you tell me what the differences are Between the Kit for the
"Original Performance Super Kit 1967-'76 excluding 1967" and the
"Original Performance Super Kit 1967"
I have talked to a few people about this, and I believe that the only difference between the two kits would be the Idler Arm. The 1967 Idler arm mounts to the K-frame in one spot. Whereas a 1968 has two mounting spots. Is this correct?
I will post a picture in a little bit of the Idler arm that I removed from my car. Maybe you guys can help me identify it from that.
