These vehicles were daily drivers. Daily aint always smooth sailing. break loose some ice or snow, slide into a curb, and toe setting would change. It wasn't the arm itself but the single tab holding it that bent. that is why it changed to a stronger attachment.
A much worse collision could and would distort the whole K member. Owner dont know it until they remove the 4 large bolts that attach K member to frame rails. When they go to put it back, the bolt holes line up 2 or 3 out of 4. Some have found it the hard way. They bought a K member from a wrecked car in a bone yard. got it all painted and ready to throw away .
Tjis thread is not about entire K but just the early idler arm attach. My point is, find one of those warped K members from 68 up. Cut the 2 ear idler arm attach off and weld it onto the 67 K member. With some measuring you'll find the single ear you removed is right in the middle of the 2 ears you add ( so adding a ear above or blow that ear doesn't work just right).
I already have that piece from a 75 slant 6 K to weld on my 67 K when I need it.
