matthon
- Joined
- Aug 29, 2008
- Messages
- 3,046
- Reaction score
- 1,433
Disassemble my manual steering column, it came apart quite easily.
The plan was to rebuild and get a new manual box.
Is this shaft junk?
Worn where the lower bearing should be, and it appears the collapsible shaft is extended.
I did a bunch of research on rebuilding a 67 one year only column, and just replacing the few parts adds up, more importantly I was unable to find info on my situation.
Is there a direct bolt in aftermarket column?
Is my steering shaft usable, or fixable?
Or is my only option a replacement shaft?
Is this shaft junk?
