Hello team, just got one of SlantSixDan’s signal switches last night. My original ‘67 is wired a bit different from the one I got. I did color for color as I replaced each wire in the connector. Since I can’t add pictures to show dan on the private messengers, I figure I’d post them up. Dan assured me it will work, but do to operator error I maybe hooking it up wrong. What you’re take on this?
Here’s the connector, I replaced one wire at a time same color or close too.
You can see the switches are wired different. I’m not sure if replacing each wire for the same color is right. Only because the location of the wires on the switch are different or is the internal part of the switch made different and therefore the color of the wire is correct.
