67 & up A body parts to trade
Sedanman
67-9 Valiant specialist
chicago Il
I have a ton of parts to trade. Pics attached
I need the factory 8 3/4 axel end adjuster plates
black 8mm plug wires with 90 degree boots for dist
more
more
and more
I would also love to make a package deal. The rockers only come with the standard pushrods. The list is as follows
Door hinge bolts
Trunk lock assy (no key)
60's steel pcv valve
Chrome dist hold down & bolt
Billet T stat housing
factory t stat housing
complete cigar lighter
Chrome volt reg cover
VDO guage pod with block fittings for all engines
PB intake fitting
70's small block pulleys & alt bracket. non a/c w/ ps
carb stud
T sig lever
11x2 backing plates
727 trans yoke,sml
sm blk oil dip stick
Small shaft pb push rod
d shaft straps
Right angle oil filter adapter
2 sets of ARP 3/4" header bolts
Matched set of 69 & under small block pulleys for cast iron water pump & man steer
67 valiant grill set ups (no center)
glove box lite harness
68 valiant RH fender
67-9 2 dr sedan chrome door panel chrome bezels
Jaz racing seat with expired harness
I only get 1 day off a week & I try to spend it catching up on sleep so shipping large stuff is too hard
The ARP bolts are header bolts,3/4 long & 1 set is new & the other is used. There are a few extras
