67 Valiant Windshield
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
So I am going to need a windsheild gasket to do my dash swap.
67 and 68 are calling for the same part number but if I recall, there was something goofy about the original 67 Gasket.
The 68 to 76 will work on a 67 ?
yeah, 67 has that chrome strip insert where the 68 and up use the clip on trim. You will need to install clips if you plan to use the chrome
Seems like converting it to the stainless trim is a lot better than messing with that plastic chrome stuff that seems nearly impossible to get ahold of.
Thanks for all the insight
There's a reason Ma Mopar made the switch, so if it's not a 100 point resto....
A reproduction plastic strip is available.
It is not concourse correct but...
I swapped our 67 cuda over to stainless(68+). I could send you some shitty brittle mylar lol..Precision sells it new.
A 67 gasket and 68+ gasket are 2 different animals. Why are they showing the same part #'s? Somethings not right
I think i have some 67 windshield stuff.
Locking strip and the beloved corner peices.
Ill send it with that stereo stuff that is collecting dust
Still rocking a sled with that mad base?
