[SOLD] 68 69 AM Fm rollknob radio
badlilred79
badred360
Crossville TN
Rating - 98.3%
57   1   0
I have a 68 69 B body roll knob radio AM FM the light lights up it's all I know it changes from FM to am I know for a fact it works I have it and I have a video I can send t your email of it plays tested wires have been cut I showed in the pictures but it's still a rare radio $450 plus the ride Crossville Tennessee
If it works I'd buy it. Anyway you can put an antenna on it and a speaker and fire it up?
there is a DANGER on all old mopar radios that i found out with a lot of research!!
you CANNOT connect a modern speaker to these old radios!! if you do, you will burn out the "transistors" in the radio. i found out that the old radios require 8 ohm speakers. all NEW speakers are only 4 ohm and they will burn out the transistors in an old radio! DO NOT try out an old radio hooked to any speaker. you will burn out the radio.
Thanks I used a old speaker and it plays really good on FM and am I have a video of it playing I have to send to a email it will not let me post it on hear I done try 4 times keeps saying file to big. It plays still for sale
If this info is correct, then all you have to do is wire a 4 ohm resistor in series on speaker wire.
