Look under the upright one as well, then under the Buckets, then behind the glove compartment. I saw one in the headliner.do you have the fender tag?
Instead of looking under the back seat, look inside the springs of the lower portion of the back seat; I found about 2/3 of mine there (and some rodents found the rest before I got there).
why are you so worried about the b sheet
when you have all the other documentation.
So did you go look under your back seat cushion yet?? :-D
You did look under the front seats right?I also have heard they have been found behind the seat back on bucket seats.
seeing that the cuda needs a fresh headliner i pulled down the oldone hoping to find the b sheet. nothing. i also pulled the rear fold down seat apart and looked there nothing there either. where abouts were they in the front buckets, other than under the bottom springs? and also where were they located under the carpet? thanks
