68 Barracuda Front Suspension Rebuild Kit
Revisiting this. What about the tie rod ends and sleeves?
your original ends and sleeves should hook right up.
or were you asking about buying new? if so, i'd avoid moog unless you're okay with the possibility of having to sift thru and send back bad ones.
proforged and mevotech supreme are what i've been using lately.
Yes, I missed that. either 9/16 or 11/16 will bolt between to your centerlink and steering arms (lower ball joint).
They both have the same ball joint stud taper.
thank you for succinctly summing it up. i was grasping with how to properly articulate that the things and the stuffs are the samesies, but just buy good stuff so as you don't gotta mess around.
I was curious if there was a difference in the year for the tie rod ends and sleeves. I.e. I need either 67-72 or 73-76 parts for those.
No, they list same parts for 67-72 and 73-76 A-bodies.
If you want the thicker ones try 72 Dodge Polara
Take a look at the part list below. Can you confirm that these would all be correct?
Upper Ball Joints - qty 2 101-10126
Lower Ball Joint - qty 1 101-10128
Lower Ball Joint - qty 1 101-10129
Inner Tie Rods - qty 2 104-10156
Outer Tie Rods - qty 2 104-10157
Tie Rod Sleeves - qty 1 105-10048
Rear Sway Bar - Hellwig 6907
Front Sway Bar - Hellwig 5906 (currently 205/60R15's but thinking 215/225's eventually for handling)
I only know moog numbers:
For 73-76 Disk spindles:
  • Upper Ball Joints - qty 2 K727
  • Lower Ball Joint - qty 1 K783
  • Lower Ball Joint - qty 1 K781
Tie Rods:
  • 9/16"
  • Moog ES401R - outers
  • Moog ES401RL - inners
  • moog-ES319S - sleeves
  • 11/16"
  • Moog ES352R - outers
  • Moog ES355RL - inners
  • Moog ES440S - sleeves
