68 Barracuda Hemi swap
I reworked the gauges with VDO guts over the old displays, I found a guy to swap the L & H and the C & H on the temp and oil displays, those are stick on. The amp meter is now a volt meter. That took a while to do.
Floor console as it is now. That took a lot of massaging to get to fit good. Bought repro 4 speed console cover, nos shifter boot. Bent up shifter handle came with the SST trans kit.
I reworked the gauges with VDO guts over the old displays, I found a guy to swap the L & H and the C & H on the temp and oil displays, those are stick on. The amp meter is now a volt meter. That took a while to do.View attachment 1715586068
Do you have any more pictures of this process? I'm planning on doing the same thing in the next couple months. Curious mainly about how you mounted them.
Thanks!
That’s about what my 2004 came out at. I had 323 gears. Car looks great. I think my numbers where hp328 375 ftpb
