[FOR SALE] 68 Dart GTS
68 Coronet RT
68 GTS # 508 in Registry
Upstate New York
Rating - 0%
0   0   0
Dodge Dart GTS. That was Professionally Inspected. Numbers Matching Motor and 727 tranny that was just completely rebuilt. The LS23P8B125 GTS was built September 8th 1967 at the Hamtramck Mich. Assembly Plant. Car has original Fender Tag and Build Sheet.
Stock Block with X heads with a production date of 6/22/1967. Hughes Engine cam kit 518 lift 224 duration, new lifters and springs, New Timing chain and gear. New Pertronix Electronic distributor w/rev limiter. Edelbrock Performer RPM intake ( I have the original ), Edelbrock 650 AVS-2 Carb. Stock exhaust manifolds w/ TTI 2 1/2 inch H pipes w/ dyno max mufflers. 8 3/4 posi rear w/3:55 gears ( I have the original 3:23's ).Mopar Super Stock Springs ( I have original springs ).New Vinyl top and headliner. New Lengendary Aluminum Mag 500 wheels 15X7 fronts 15x8 rears. New BFG Radial T/A's 215/65/15's up front 245/60/15 rears. Kelsey Hayes Disc up front Drum rears on 4 1/2 inch bolt pattern. New Direct fit Cold Case radiator and shroud ( I have original Rad. ).All original floor and trunk pan as is the frame rails in excellent condition. Interior vinyl seats and seat foam was replaced in 2006 The car had complete restoration in 2000, all original sheet metal except the left rear quarter Turn Key car listed as # 508 in the Dart GTS Registry. More Photos upon request.
$34,500
