I installed a Bosch type relay to power the Ford type solenoid and used the Neutral safety switch for ground.
This ain't pretty (diaghram).
I see. thanks
---Agreed George, stunning!
Heck, tighten up that sagging roof and put some lights and a fan in there, paint booth!One of the nicest darts I've seen.
I got something for you while you wait for fall to roll around to work on the dart.
Unlimited beer and bbq
---Now we can start negotiations! Nice job!!!
---What brand is your Hemi Dart hood? I’m looking to buy one that’s made well
---Also how did you do the cut outs for the back wheels? Did you use a pattern? I’m looking to do this but I don’t want to over cut the back. Thank
Thanks, So the scoop wasn’t on the hood when you purchased it?---
Both my hood and scoop came from AAR. I did my research before buying as you are and came up with AAR. No regrets at all. There was nothing to do but drill and fit the scoop, sand, prep and paint. I also bought the bolt on hood, and I can either pin it or hinge. 6 lbs difference between the 2.
---Thanks, So the scoop wasn’t on the hood when you purchased it?
Do you think I can just buy the scoop and put it on the metal hood?---
No Sir. They are shipped in separate boxes. Apparently past shipping experiences proves this to be the best safest. Boxing of products is as good as it gets. They will drill the scoop holes for you if you choose for an additional cost. I chose to drill my own holes.
Sure can. 2 weeks for my order to showDo you think I can just buy the scoop and put it on the metal hood?
—-how is the engine parts collection going?
How did you fold inward to build inner lip? I wish you made a YouTube video---
Lots of research, pictures, then made my own cuts. I used the old existing left side panel to come up with my shape. Once cut I made templates. Then transferred to the new AMD panels once they were installed. Some pictures to help out.
Same templates, just flip over for side to side.
First initial marking and cut
Second marking - final height. Cut up to line and fold inward to build inner lip.
---How did you fold inward to build inner lip? I wish you made a YouTube video
