68 dart reverse switch wiring help
4.20
Member
hi
here's what I ve done, I've swapped out the org slant six for a 318. the connector on the new auto trans is on it (three wire, brown=neutral sw, white and violet=reverse sw, or so I believe) my problem is I don't see where to reconnect the reverse wires to the body wiring (neutral sw goes to teh starter relay). I expected to see two wires at the bulk head connector on the right side, top two right hand wires, but when I look, there's nothing there. would it be in the coloun or something?
Thanks
On a 68 the reverse light switch is on the shifter, either in the console or low upper side of the steering column. Therefore your reverse lights are probably still wired and working. You can move the wires to the trans mounted switch if you like, now or later. Happy Moparing
thanks, found the switch at the bulkhead, still works.
cheers
