68ddart
i have a 68 dart converting from column to floor and need the bracket that mounts with two bolts on the side of the shifter to the linkage that goes thru the floor located right above the boot in the picture,it keeps it in line and the switch on the side of the shifter and the sleeve that goes on the column .also the bracket in upper left under the shifter lever.these are not my parts i just used this pic to describe what i am missing
