twotone68
lifetime mopar man
I have put my second fuel sending unit in my 68 dart,2 dr. sedan. Both have been from Van's Auto Parts. I thought it was a ground problem. I now have a ground at the hard line before the fuel pump,a ground going from the sender to the body, aground from the hard line to the body, the block is grounded to the fire wall, the battery to the head. The factory ground on the back of the guage cluster goes from the volt limiter to the column support bracket and also to the column. The guage works off and on during cold weather or rainy weather. Nice and hot days it is on empty constantly. i am out of Ideas !!!! Any one have any suggestions. This is a daily driver that is being restored and has a 318,904,7 1/4,the tank is stock,has a new insulation pad between tank top and trunk. I have a electronic guage volt limiter. HELP !!!!!!:banghead:
