hello all,
Here's whats done. removed orginal /6, now has '82 318 with newer distributor (magnetic pickup, P3874909). The ignition module has not been changed, it is a P3874020 (I believe this to be the proper one, 5 wire with a two connector resistor? it ran with whatever dist. was in the org slant). not sure why but don't seem to get great spark. has new cap, rotor, wires,plugs. Does the wring have to change with this different combination of distributor and module?
Thanks for the help
Cheers
Thanks for the help
Cheers
