dart540
68 barracuda 12pt.,cage tubbed.narrowed 8-3/4 braced spool,axles gears,coilovers with old 4-link setup,front mopar disc barkes,line loc msd6 ign blaster coil fuel cellw/sending unit.factory dash,wiring,all glass and windows,work carpted.Auto meter tach and gauges,New 440/451 eng Indy sr/heads fully ported,new lightened wiesco/pistons new mgp alum.rods, new comp cams solid 650 lift,new lifters,all machine done with recieps lifter bores bushed hard block filled new eagle crank cut for 2.2 rods plus manifold carb,dist,plus much more/,to much to list pro stars on front goodyears on rear ,with centerline rims plus new rebuilt 727 tranz and new frank lupo 8in. converter.Motor needs assembled and comb.needs installed.PM if truly interested 16,500 pictures to follow tomorrow Thanks Stan.
