69383valiant
It is what it is...
Very nice pipes look good... Can't wait to hear how she runs when mash the loud pedal. Lol
Very nice work!Well, the engine and transmission were both dyno'd, so all i had to do was bolt on the carb and drop in the distributor and turn the key. I had quite a bit of trouble getting the starter to work with the correct positive battery cable connection, so i had the header, torsion bar, etc off and on so many times i could do it in my sleep. I fired it up and very slowly ran it up and down the street to test everything like the "BRAKES", before i smash the gas pedal. The car shifted and acted very good with no major problems other than some small issues. One problem that i may have is cooling, "surprise, surprise", It seemed to cool at idle but gets hot moving. Im going to try a high flow thermostat and one large elec fan in place of the shroud and the two smaller units. I just dont think they are moving enough air. I may even try a stock shroud and fan. I drove it a total of about 1 mile, so im not getting real worried just yet. I set the timing at 38 deg, so i may play with that to see if that may be the issue.
HAHA! It was an original vinyl top car! why don't you like them???? White car with a black top wouldn't look to bad!dan the car is looking good.... SAY NO TO VINYL TOPS!!....control yourself brother
