abodyjoe
I agree... but a some of the older guys that lived through the 'era would not want a '68 360 Dart or 'Cuda.
Those guys are getting older and older now and buying modern muscle or dying off.
If you have an intake and exhaust manifold slap them on though a carb on then motor and try to get it to fire up. As is. Not every seller is bad I don’t think it will kill you or hurt anthing to bolt on some parts and try to fire it up. I don’t like all the tear it down responses added work that may not be needed. I’ve bought quite a few motors that dident have a carb or what not and I through some pile of **** carb I had in gas and the motor fired up again with the 508 cam problems lol.Hello,
I just purchased a ‘69 340 that I plan to swap into my ’69 318 automatic Barracuda. I was told it was a running engine before it was yanked out of the vehicle. The original owner sold the carb and intake separately. I was also told it has a 508 camshaft that needs to be broken in and it’s a standard bore. I’m not sure why the camshaft was replaced in the first place especially if he had planned to sell it. That’s all I know about it and any information I don’t know I’ll have to discover myself as I cannot contact the original owner.
I’d like to get people’s opinions on what the best course of action would be to get this engine running. Should I pull the heads to see exactly what I have? Should I put an intake and carb on it and run it? I’m hoping to not do a full rebuild since the engine was running.
Right now my plans are to use a stock 340 intake that I already have, 340 exhaust manifolds and I’d welcome a carb recommendation. I do have a Edelbrock 600 cfm (1406) if that would work, but I’m not opposed to getting a different one if need be. I’m also not opposed to a camshaft swap if need be.
My objective is to have a good running and reliable street engine. I’m not looking for a high horsepower race motor.
I am new to engine work but it is something I’ve always wanted to do and what better way to learn?
I understand there is probably more information I need to provide so please ask away.
Thanks to all,
Mike
IMHO there has been a lot of crud in there. The cylinder's wall's shininess/glazing is my bigger issue.... I have to highly question how well the rings are sealing anymore. I would expect a lot of blowby when you step in the gas with bores looking like that. And then that leads to questions on overall ring condition and wear on the ring lands. If the ring lands are sloppy, then the rings will never seal well.Thanks, I'll check the casting number tonight when I get home and I will eventually get the pan off and will report what I find.
I apologize if this question shows my ignorance, but does it matter that the scoring on the cylinder walls is so minor that it's difficult to feel with a finger nail?
That's a problem? LOL Lemme tell you some of MY spill stories....DOHdrain the oil b 4 flipping engine over ask me how I know
Take the pan off and check a bearings What is the casting number 340-what? That will determine if you can go .040 it should sonic test ok if its a low number. 340-1 is the best 340-8 would be the worse
Flip the engine over and take off the oil pan. Take the oil pump off and measure inside clearances and look how badly the tips of the pump rotors are chipped/gounged/scored and that will give some idea of how dirty the engine may have been. Then pull some rod and main caps and look at the bearings; that is going to tell more about how well/poorly this was built and how it was maintained, and what you have going forward..
The final bit is to pull a piston or 2, like from the cylinder shown after the rod cap is off, and look at the piston skirts. I suspect you will see a lot of scoring, and if there are any dark patches on the aluminum skirts, then the pistons got too hot. You can also examine the ring side clearance (which tells land and/or ring wear)
b 4 you take any pistons out check the deck clearance plus or minus at all four corners and report they should all be close to the same
measure the thickness of the outside head bolt casting- about an inch- do each end of each head they should all be close to the same
One problem with measuring this and getting a solid answer is that the rod lengths can vary, especially if any reman rods have been put in there; you just don't know about that at this point. And if the crank as been turned poorly, then that is a another source of variation in deck heights. The only completely accurate way to know is to move the same piston+rod from hole to hole but that does not get rid of crank variations. If I wanted accurate measurements for a flat deck, I'd measure after all the new parts have been assembled and checked for consistency.
Plan the build and you will never regret it. It is more costly to build it twice than to build it right once.
Cook and clean the block Clean Clean and Clean some more.This makes complete sense. There is a lot of stack-up that will introduce a wide tolerance in the end. I think I'll take the measurement anyway as it is good practice and a chance to learn something new. I will be curious what the dimensions are though.
I agree, I'm taking it slow but in the end I have no issues taking it to a machine shop to get it checked/cleaned/machined. I do want to be able to build as much of the engine myself in the garage with my nephew. You mentioned having the shop fit the crank bearings, aside from that and the machining what other tasks should I definitely have the machine shop perform?
Thanks,
Mike
I think you mean cam bearings, not crank bearings.You mentioned having the shop fit the crank bearings, aside from that and the machining what other tasks should I definitely have the machine shop perform?
