69 Barracuda grille disassembly
67dodgedartconv
pass christian, mississippi
How do you separate the outside chrome trim from the plastic housing? Do you have to drill out the rivets? Don't see how rivets could be holding chrome bezels to the plastic. Thanks for any help from those that have done this.
The chrome trim on the grilles is chrome plated plastic also, I think its not rivets but swaged plastic tabs.
Heres a link to a thread I started when I started on mine. Looks like pics disappeared, BUT if you click on the filename of pic, it shows up.
Hope it helps.
1969 Cuda Grill Resto...any tips/tricks??
Thanks, so the chrome pot metal outer surrounds have cast-in rivets that are peened over to the plastic grill housings? To reassemble you epoxy them back together?
