69 charger?
unknownsnake
Mason, MI
is that a b body? it has a 8 3/4 is that one that just little longer then a body?
That depends on a lot. Does it come with a center chunk? What gears? Is it a sure-grip? What are you going to put it in?
$150 doesn't sound bad for the housing and center chunk, but it won't be a direct bolt in for your '73 Dart. You'll have to move the spring perches and either run narrow rims, a lot of backspacing, or you could narrow it to A-body width.
a lot of backspacing? i think its only 1 .25 inches different on each side and a half inch on the perches lot of people just bow the springs in the half inch.
