69 cuda wheel size
I just went out and took a look. 255-60-R15 Radial TA's. But, the pass side is only about 1/8" from the rear spring on the rear. Be sure to check yours carefully before going for the 4.25" offset. 4" may be safer if the rear axle is not assembled perfectly or if one of your spring clamps happens to be right where the tire is closest. Tom
I have 225 70 15 (front)
275 60 15 (back)
4.5 Backspace (BBP)
But the damn right tire touches the inner fender lip.
Very soon the fender will be pulled I or moved but before I do that I'm installing 15 x 4 inch rim in the front and hoping a shorter tire will eliminate this issue.
Thanks.
Maps
