[FOR SALE] 69 Dart GTS front suspension
niceolddart
S.E. Pa.
I have a complete front suspension set up including torsion bars, from a real 69 Dart GTS 340 4 speed car. Selling as a unit & will not separate! See pix. Also have "A" body 5 leaf springs from same car, (good shape) but cannot say if they are original to the car. $600 for the front end, & $75 for the springs, or make me a reasonable offer for either. May deliver if within 25 miles, otherwise you must come & get them. I may have other suspension parts available from this car too, just ask. 19067 zip code, S.E. Pa. Thanks
Hi was wondering if you have a steering column bracket to dash? Is a power steering tube style I have manual steering bracket and doesn't line up for bolt hole on the tube. Thanks
[QUOTE="Tomo, post: 1973022154, member: sorry I hit you up hoping you had a bracket for steering column. I'm not needing any springs sorry.
No problem on the column brackets Tomo. They are staying with the car. As far as the rear leaf springs 68bee, I will check the numbers but I don't think they are original pieces. I will get back to you later today on those. Thanks. (This is a friends car getting a complete RMS front & rear suspension set-up, that is why he is selling these parts.)
OK and thanks was only after steering column bracket.
