69DARTS 69 Darts Rule Joined Aug 5, 2008 Messages 10,042 Reaction score 499 Location indiana Nov 13, 2021 #1 Ok what i have is 69 dart oe power steering pump I have instaled a 72 340 What braket do i need to make the work correctly
Greasyfingers Well-Known Member Joined Jul 16, 2019 Messages 403 Reaction score 432 Location Morgan Hill, CA Nov 13, 2021 #2 You need the bracket for the later aluminum water pump, so 1970 and up. If you have all the brackets and pulleys from the 69 motor, just get a pre 1970 cast iron water pump.
4 413 Well-Known Member Joined Nov 13, 2019 Messages 1,213 Reaction score 2,047 Location NW USA Nov 13, 2021 #3 That PS pump bolts right to the cast iron water pump. The aluminum water pump you have is different and no place to use those brackets.
CRUZE 418 FABO Gold Member FABO Gold Member Joined Mar 11, 2019 Messages 2,317 Reaction score 1,442 Location Illinois Nov 14, 2021 #4 If you need the room, the cast iron pump is 3/4" shorter, but the water pump pulley will be different.
chrgdrt Well-Known Member Joined Nov 1, 2009 Messages 475 Reaction score 283 Location Richmond, Mi Jan 31, 2022 #5 The outlet is on the opposite side also
