Lots of reading I’ve done with tire sizes and offset hangers/spring relocation to fit 275s in a 69 dart with stock tub and stock 8.75in rear end.
275/60/15 will fit with stock tub and 1/2in offset shackles or 3in spring relocation. But don’t do 3in spring relocation unless doing a mini tub because you don’t gain any extra space over the 1/2in shackles. Correct? To get the tires to fit you need a 15x8in wheel 5in offset or 5.25in offset wheel?
Now here is my dilemma. I want 275s because 245 isn’t enough tire and that’s all I can run on my other 69 dart with stock spring location.
I also want rear disc brakes, because I do not like the drums on my other 69. But disc brakes move the tires out an extra 1/2in correct?
So to get 275s on the 69 dart With Disc brakes, is it required to do the 3in spring relocation and mini tub? Or will I still be able to do the 1/2in shackles as long as I nail the wheel backspacing?
First photo is new dart other photos are purple dart with stock spring location, 245/60/15, SS springs, drum brakes. About 1/2in clearance on passenger side with rolled lip and 3/4-1in clearance on drivers side with rolled lip.
