'69 Dodge Dart GTS
After I get the Barracuda out I can drop the motor in the Dart.
If it all goes as planed i will have a running car by Friday. George R (or any other member) Do you know the measurements for a '69 GTS stripe? Thanks
Kegan,
I have a piece of an old Dart trunk stripe here that I can measure for you if you need it, but I won't have access to it until about 5:30 ET.
Do you plan to lay out the stripe on the car, then paint it on or something??
George
Kegan,
George
Yes I'm going to make a template then paint it on, is what i'm thinking.
Maybe even do some air brushing to it.
The 340 & 727 (til i can get an 833) are now bolted in the car.
Its also now in the GTS Registry #526.
Keep up the good work kegan, you're making good progress
some installed engine pics :burnout:
Thanks Cliff. Going out when its daylight and doing the header install
Just to put it out there I Know what its worth done up as a trailer queen but its staying a driver/racer!
After I get a thicker gasket under the carb it'll run better.
Changing master cylinders tomarrow mine rusted up (almost hit the garage the other day). Got the pass. door almost all stripped of the purple tint.
I plan on getting the water pump on rad in and rebuild my 650 tomarrow.
I Don't think ya'll would want a vid of when I break in the cam would ya ?
