Longgone
John/68 Barracuda & Dart
I`m helping Fishman put a 408 stroker (360 based) motor in his 69 Barracuda. As you guys know the water pump/timing cover changes for the 70`s cars along with the power steering pump and brackets. The engine we`ve installed is a 74 360, and it`s replaced the original 69 318. The problem we`ve encountered is with the new water pump (that opens to the right side, not the left as the original did) the ears that would normally create a mounting point for the power steering pump are not there. The 69 and earlier pumps open on the left side and have a boss for mounting the steering pump. This new pump doesn`t have the boss. We`re trying to use the 69 steering pump with the later 70`s up water pump. Has anybody got any advice here, is there another bracket that`s available that will fit that steering pump to the newer water pump? Thanks.
