Arturo Meneses
Member
Would a carburetor from a 69 valiant fit my 65 Dart? The dart comes with a rotating rod. Thanks!
Nope you need the 63-66 Rod Type lever, but you can swap swafts, or weld the rod attachment, Or you can get a 64-66 Early A V8 Pedal cable set up, and get the 1967 to 1972 slant six Cable mount bracket and kick down set up.Would a carburetor from a 69 valiant fit my 65 Dart? The dart comes with a rotating rod. Thanks!
ThanksNope you need the 63-66 Rod Type lever, but you can swap swafts, or weld the rod attachment, Or you can get a 64-66 Early A V8 Pedal cable set up, and get the 1967 to 1972 slant six Cable mount bracket and kick down set up.
