I actually went though this exact scenario Yukon88. I have a 69 valiant 2 door that was s/6 and auto. First I put a 318 in there with the schumacher mounts and a 727. The schumacher mounts did do the job just fine. But I decided to finally do a k frame swap and now I have a 340 with an a833 4 speed. So here is my advice on it from what I went though.
If you are looking to go to a a833 the hardest part is going to be able to find all the parts you need. It took me a while to gather all of the parts for the 4 speed from here and I lucky found the transmission it self around town. You will be spending $$$ for these parts so it adds up!! As for the power steering im sure you can make it work, but you will need to do your research! I went to manual steering just for the fact that I didn't want "drag" on my engine... but now looking back its not really a drag car so I do miss the power steering, and to find a manual box then you have to find a longer steering column because they are different lengths ( buddy of mine helped me customize my power steering column to fit the manual) This is a headache all by itself. Sorry I am rambling on but as you can see one problem will lead you to another so plan it out, ask your self what do you want this car to be, drag? street? show?
TL;DR Any customization will cost you money, and you'd be surprised how changing one part affects others, so do research before jumping into it. One thing is for sure these guys on here are great and listen to them and ask, there good people.
