7 1/4 width question....after searching
Suspension, Steering and Chassis
  1. 69moredoor
    69moredoor Well-Known Member
    168
    129
    May 5, 2019
    VA
    Local Time:
    3:27 AM
    Looking at what 7 1/4 rears would fit in my valiant that are the same width...
    So 64-72 are the same width (53” and change)
    73 and later 7 1/4’s are slightly narrower? (51” and change)
    Am I correct?
    And all are small bolt pattern?
  2. Lee Robinson
    Lee Robinson FABO Gold Member FABO Gold Member
    6,646
    404
    Aug 23, 2009
    El Dorado Hills, Ca.
    Local Time:
    2:27 AM
    73 and up, can be BBP if they came from a disc brake car. I don't know about the width difference.
    • Agree Agree x 1
    • 69moredoor
      168
      129
      May 5, 2019
      VA
      Local Time:
      3:27 AM
      Bump for more info
    • cudamark
      cudamark FABO Gold Member FABO Gold Member
      7,204
      462
      Mar 14, 2009
      San Diego
      Local Time:
      12:27 AM
      The 7 1/4 A-body rear ends with small bolt pattern are all the same from '63 through '76 except for some of the brake parts. Now, comparing the small bolt pattern 7 1/4 with the big bolt pattern.......I don't know. I haven't done that measurement, but, I doubt there's much if any difference since they came with the same track specs.
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      11,003
      5463
      Nov 28, 2008
      NorCal
      Local Time:
      12:27 AM
      The 73+ BBP 7.25" and 8.25" rear axle housings are 51.5" wide, which makes them 56 3/4" from wheel mounting surface to wheel mounting surface. Significantly narrower than the SBP 8 3/4 which are 57 1/8" and even more narrow than an A-body 8 3/4 that has been converted to BBP axles (57 13/16").
      I am not entirely sure about the exact width of the SBP 7.25's. I've heard from multiple sources that you can't just swap the later 7.25" BBP axles into a SBP 7.25" housing to convert it to BBP. Based on what I've seen for tire clearances they're probably closer to the SBP 8 3/4 than they are to the BBP 7.25". But I've never had one to measure, my only 7.25" equipped car was BBP.
      That's not an assumption I'd make. Given how different the BBP 7.25" and 8.25 are from the SBP 8 3/4 equipped cars there's no telling how different the track is. Even if the SBP 7.25" housings were the same as the BBP housings the track would be different because of the axle flange offsets (SBP to BBP 8 3/4 is different by 11/16").
    • cudamark
      7,204
      462
      Mar 14, 2009
      San Diego
      Local Time:
      12:27 AM
      I was only referring to the 7 1/4 rear axles.
    • 69moredoor
      168
      129
      May 5, 2019
      VA
      Local Time:
      3:27 AM
      Well this is clear as mud lollll
    • Garethw
      Garethw Mopar. Because rocket science is too easy.
      423
      341
      Mar 10, 2015
      Georgia
      Local Time:
      2:27 AM
      I’ve got a SBP 7 1/4 you can have for free, if you want to come pick it up. I’m about to scrap it.
    • 72bluNblu
      11,003
      5463
      Nov 28, 2008
      NorCal
      Local Time:
      12:27 AM
      Right, but my point is that the A-body 8 3/4 already had a different track than the BBP 7.25 and 8.25. So why would you assume they’d be worried about the SBP and BBP 7.25’s being the same track?
    • cudamark
      7,204
      462
      Mar 14, 2009
      San Diego
      Local Time:
      12:27 AM
      I didn't assume they'd be worried at all. I admitted I didn't know for sure about the measurement difference in the BBP vs. SBP rear axle assemblies. I've swapped them using the same wheel and tire size and had the same clearance in the wheel wells. Like I said, if there's a difference, it isn't much.
