GimmeDanger
Active Member
Hi, I have a 71 swinger 318, with a later model (I think) 7.25 rear, not sure what it is from but it had a 5x4.5 bolt pattern. It's starting to make a bit of noise and im getting some vibration. Trying to narrow down what is is, leaning towards axle bearings, I can wiggle the passenger side about a mm or so.
Either way I'm thinking of replacing them but I want to be certain of what bearings I need and how big of a job it is.
From what I've read here the bearings on later axles aren't pressed onto the shaft so doing it at home might be more feasible than an earlier one. I can say that the retainer has 5 bolts, so I think I'm right but want to be certain, my 70-76 manual doesn't mention any of this.
