Any one run these? I know they are only available from easyperformance and look pretty slick. I have a set on order, 3 week turnaround. Just was curious if someone got a set already installed.
I was having trouble with my tail/ brakes being to dim, I figured somewhere a ground is a little weak. So I went to Advance auto and bought a set, name brand, not the China junk on Ebay, about $20, they work fantastic.
For sure! I got about another 2 weeks before they come in. Supposedly no modifications to housings/lenses needed (Thankfully so @ $300+ a pop no room for error on those housings/lenses). It will be interesting to see how smooth the install goes. I will be sure to post up some pics and progress, pros/cons etc...
:rock:Got them in on Wednesday and installed last night.
Pros:
-Bright, and sequence nicely. With stock bulbs up front no need for low current flasher relay.
-Straight forward and simple looking device with stock plug connections
-Fitment in housings with plenty of clearance and center nicely.
-grounding remains on the factory socket and housing (not the aluminum mounting bracket provided)
Cons:
-additional wire (pink) needed to run sequence when lights are not "on" (park or headlamp) otherwise unit does standard flash. Sequencing and programming mode is enabled when you turn your parks on or your main headlights. (This I really don't mind as it changes things up.)
-mounting is set up for drilling your housings to mount. I opted not to and resorted to expandable weather seal from lowes. It worked really well and gives nice shock absorbsion and suspension inside the housing.
-the absence of weatherproofing on circuit board in form of epoxy or gel coating.
Overall great product and I sent them a review. Looking to see if they do any revisions to make it an all inclusive, buy and install product. As of now it leaves room for imagination and error.
