70 Dart heater/radio delete
Heater delete - yes. In warm climates like Hawaii.
Heaters were standard though, radios were options. So, you would not add an option then delete it, you would just not order a radio.
so a radio heater delete panel would be correct on a dart? what did they do with the hole from the heater box.... im building a FAST class car and was curious
Standard dash had a block off plate for the radio delete. Never have seen a rally dash with a radio delete.
Think the factory had vent boxes with out the heater part and just put block off plates over the fire wall holes.
Thats what I did to my Dart. Cut the vent box from the heater then boxed it in and put block off plates over the fire wall holes.
okay, does anybody have pics of both the block offs for both the dash and the firewall, original, not done themselves?
