65Val
Average Length Member
Thats about the going rate for those manifolds. Try searching for the ‘69-only 440 A body M code exhaust manifolds. That’ll give you a shock.Holy hell!!
This is why I'll never get a rare car where i needed some super expensive original numbers matching parts.Thats about the going rate for those manifolds. Try searching for the ‘69-only 440 A body M code exhaust manifolds. That’ll give you a shock.
Fenderwell headers are nice and can often find used sets cheap. I got mine for $250 with nice paint on them still.
A body big block manifolds...
Thanks 71GSS. Much appreciated. Looks like the drop angles are a lot different from the b manifolds compared to the a body. I'm on a low budget and if I knew the b manifolds could work like you said I'd consider them I guess based on price.
This is my opinion and my opinion only.
If your engine builder says that using stock log cast iron manifolds isn't going to hurt performance on a tunnel rammed big block with a cam in an A-Body, it's time to find another engine builder.
You will lose at least 50 or more horsepower alone using them with your set up.
Now, if the engine was dead stock, the hit wouldn't be so bad.
If I were you, I would look on BigBlockDart.com and do some reading, there is a lot of info on there about using stock manifolds versus headers (both cheap and expensive) and the fitment issues with all of them.
My brother back in the early '80s bought a '71 Duster with a mild 440 in it that had the exact manifolds that you pictured on it.
We swapped out them for some Hedman B-Body headers, and the difference was astonishing.
Sure, they were a pain to install, but the difference was night and day.
If you can find them go with shumacher headers, might find some that someone is selling to go to full length headers.
Thx 71GSS! So those are b body HP manifolds, right? Very much appreciate those pics! Looks like casting # 2849982-2 for the drivers side?
